Pontiac tech guys HELP
  • Pontiac tech guys HELP
    Working on a 03 grand prix
    Shifter stuck in park unless you manually force the solenoid at the shifter, also the key is stuck in unless you manually force the solenoid on the colum. Replaced the brake switch that forces the shift solenoid to work and still nothing. I have tested the harness to the shifter and its working as it should?
    What am i missing? I haven't tested the solenoid on the shifter itself?
    Would this still tell the key solenoid that the car in not in park. IE you cant remove the key?
    Help
    We used to put a lot of new shifters in those car back in the day as I remember.
      Were can i find one? I can find the solenoids, but not a complete shifter asy.
        Not sure how far back you can go but the East Bethel Upull has this:
        NA4463 Pontiac 2002 Grand Prix silver 4d 12/10/2013
        NA4284 Pontiac 2001 Grand Prix maroon 4d 11/22/2013
        NA4404 Pontiac 2001 Grand Prix black 4d 12/05/2013
        NA4307 Pontiac 2000 Grand Prix red 4d 11/26/2013
        If it's a part that is commonly fails, make sure to check it out before buying. Sometimes with parts like that you can retro fit an earlier or later version to get around the hassle. I see people do it a lot on other GM products.
        http://www.upullrparts.com/home
